Hello
I have a question about the implementation of "apps \ waf \ ota2_bootloader \ ota2_bootloader.c" in the sample code.
When "ota2_failsafe_app_load" is called, the following processing is performed.
/ * Check boot_type FAILSAFE-if so, use ota2_failsafe to recover * /
BOOTLOADER_PRINTF (("Bootloader: boot_type =% d! \ R \ n", dct_ota2_config.boot_type));
if ((dct_ota2_config.boot_type == OTA2_BOOT_FAILSAFE_FACTORY_RESET) ||
(dct_ota2_config.boot_type == OTA2_BOOT_FAILSAFE_UPDATE))
uint32_t entry_point;
platform_led_set_state (PLATFORM_RED_LED_INDEX, WICED_LED_ON);
platform_led_set_state (PLATFORM_GREEN_LED_INDEX, WICED_LED_ON);
if (ota2_failsafe_app_load (OTA2_IMAGE_FAILSAFE_APP_AREA_BASE, & entry_point) == WICED_SUCCESS)
platform_led_set_state (PLATFORM_GREEN_LED_INDEX, WICED_LED_OFF);
wiced_waf_start_app (entry_point);
If "OTA2_BOOT_FAILSAFE_FACTORY_RESET" or "OTA2_BOOT_FAILSAFE_UPDATE"
I think "ota2_failsafe_app_load" is called and failsafe is implemented
Please tell me how "OTA2_BOOT_FAILSAFE_FACTORY_RESET" and "OTA2_BOOT_FAILSAFE_UPDATE" are distinguished in "ota2_failsafe_app_load".
if your OTA2 image already was uploaded to staged area successfully, then board will reboot to extract the staged image.
if you keep pressing reset key while extract , it will go to OTA2_BOOT_FAILSAFE_UPDATE:
you can see it from ot2_failsafe.c
if your running app goes to die and watchdog happens.
it will go to factory reset , the logic should need a confirm.
OTA2_BOOT_FAILSAFE_FACTORY_RESET should happen.
you can have a try to see if your evb turns into bricks with or without staged image.
Thank you.
The question has been resolved.
