About OTA2 debugging
HiIg_4537276
10 replies posted 5 replies posted 5 questions asked
Hello
I have a question about how to debug OTA2.
When I try to debug OTA2 using the sample code, there are places where it doesn't work.
(1) When debugging, breakpoints cannot be executed with boot loader related code.
This is because the boot loader processing has already been completed.
Please tell me how to set up Wiced to debug the boot loader.
(2) Currently "apps \ waf \ bootloader" is the build target.
Please tell me how to change "apps \ waf \ ota2_bootloader" to a build target.
Thank you
Zhengbao_Zhang
250 sign-ins First comment on KBA 10 questions asked
if you are using a debug mode, refer this link  to make your board run a good debug mode.
Re: Problem with Debugging
then I am using 4343WWCD2 to have a debug.
1.  check the debug mode.
snip.scan-BCM94343WWCD2-debug download
2. then use below command to debug bootloader step by step:
waf.bootloader-NoOS-BCM94343WWCD2
check this pic to have a reference.
Zhengbao_Zhang
Thank you.
I was saved.
