When I am trying to build the sample application in WICED SDK 3.4.0 demo.aws_iot.light_sensor_controlled_window.subscriber-BCM9WCDPLUS114, it is throwing the following error. Can anyone provide the solution?
Lavanya
MichaelF_56
Moving to the WICED Wi-Fi Forums
Adding vik86
VikramR_26
25 sign-ins 10 sign-ins 10 comments on KBA
I believe there is a syntactical error , or can you quickly run "clean"  and try again.
Kindly attach the source code, if you have modified it
I didn't change anything in the source file except the Client AP credentials. When I tried to build the subscriber and publisher from pub_sub directory, they were building without any issue. Only demo.aws_iot.light_sensor_controlled_window.subscriber-BCM9WCDPLUS114 is throwing the error.
Lavanya
Could you share the bootloader.log and complete build log as a txt format. I'm able to compile with no errors.
