Hello.
We develop a board with the same processor in CYW943907AEVAL1F.
We mount CYPRESS S25FL064LABNFI010 instead of MX25L6433FZNI as FLASH.
I modify CYW943907AEVAL1F.mk row 62 from
GLOBAL_DEFINES += SFLASH_SUPPORT_MACRONIX_PARTS
to
GLOBAL_DEFINES += SFLASH_SUPPORT_CYPRESS_PARTS.
We used OLIMEX ARM-USB-TINY-H as programmer and I launch this make target
"My project location"-CYW943907AEVAL1F download run JTAG=Olimex_ARM-USB-TINY-H
The debugger log says that's all it's OK but my APP doesn't start.
I try to modify sflash_write.c to execute this steps in order to understand if FLASH can be programmed properly:
/* init */
if ( 0 != init_sflash( &sflash_handle, 0, SFLASH_WRITE_ALLOWED ))
DEBUG_PRINTF(( "init_sflash failed!\n" ));
return -1;
/* erase */
DEBUG_PRINTF(( "1. erase\n\n" ));
if ( 0 != sflash_chip_erase( &sflash_handle ))
DEBUG_PRINTF(( "sflash_chip_erase failed!\n" ));
return -1;
/* write */
int i = 0;
for(i=0;i<256;i++) data_transfer.data[i] = (uint8_t)(i&0xFF);
DEBUG_PRINTF(( "ADDRESS HEX\tWRITTEN HEX\tREAD HEX\n" ));
long j=0;
for(j=0;j<32768;j+=256)
/* write */
if ( 0 != sflash_write( &sflash_handle, j, &data_transfer.data[0], 256))
DEBUG_PRINTF(( "sflash_write failed!\n" ));
goto end_test;
(void) platform_watchdog_kick( );
/* read */
if ( 0 != sflash_read( &sflash_handle, j, &Rx_Buffer[0], 256))
DEBUG_PRINTF(( "sflash_read failed!\n" ));
goto end_test;
for(i=0;i<256;i++)
DEBUG_PRINTF(( "%08X\t\t%02X\t\t%02X", (int)(i+j), data_transfer.data[i]&0xFF, Rx_Buffer[i]&0xFF));
if((data_transfer.data[i]&0xFF) != (Rx_Buffer[i]&0xFF))
DEBUG_PRINTF(( "----> failed !"));
DEBUG_PRINTF(( "\n" ));
This test says that FLASH can be programmed in a properly way ... but I don't undestand why after programming FLASH
the APP does'nt start.
Is there a kind who can help me?
- NOT_START
Hi @MaFa_974161 ,
Can you define TEST_SFLASH_WRITE and TEST_SFLASH_READ to run testing without any other code changes.
Rakesh B G
Hi ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Rakesh B G
Cypress Semiconductor Corporation
An Infineon Technologies Company
