4343W -- BT connection worked fine in WICED 6.2 and has some issues in WICED 6.4
MiRo_263836
100 replies posted 50 likes received 50 replies posted
The actual Bluetooth problem we see is that the BT Connection fails after sometime. I remember this worked
fine with the WICED 6.2.1 now we have 6.4.0 or it can be something else.. The problem seems to be
this message:  bt_rfcomm_server_conn_cback unhandled code=0x10
Where 0x10 stand for (defined in wiced_bt_rfcomm.h):
WICED_BT_RFCOMM_PEER_CONNECTION_FAILED, /**< Peer Connection Failed */
> BT stops communicating after receiving an Unhandled Management Event 0x21 which is defined as: BTM_LPM_STATE_LOW_POWER
The rest seems to work fine, but we need t overcome this issue.
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi MiRo_263836​,
Can you please let me know which demo example you are working on?
