Dear support team,
I'm preparing wl tool for get FCC certification
However, it always returns"./wl: wl driver adapter not found" when i ran
My product info
Device: Raspberry Pi 4
OS: Raspbian Buster OS
WLAN CHIP: BCM4345
uname -a
Linux raspberrypi 5.10.63-v8+ #1496 SMP PREEMPT Wed Dec 1 15:59:46 GMT 2021 aarch64 GNU/Linux
dmesg | grep brcmfmac
[ 4.300200] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.358004] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.358971] usbcore: registered new interface driver brcmfmac
[ 4.608335] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.608473] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.623329] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:20:01 version 7.45.206 (r725000 CY) FWID 01-febaba43
cd /lib/firmware/brcm/
pi@raspberrypi:/lib/firmware/brcm $ ls
BCM43430A1.hcd brcmfmac43236b.bin brcmfmac43362-sdio.bin brcmfmac43436s-sdio.txt brcmfmac4354-sdio.clm_blob brcmfmac4359-pcie.clm_blob brcmfmac4373-sdio.clm_blob
BCM43430B0.hcd brcmfmac43241b0-sdio.bin brcmfmac4339-sdio.bin brcmfmac43455-sdio.bin brcmfmac43569.bin brcmfmac4359-sdio.bin brcmfmac4373-usb.bin
BCM4345C0.hcd brcmfmac43241b4-sdio.bin brcmfmac43430a0-sdio.bin brcmfmac43455-sdio.clm_blob brcmfmac4356-pcie.bin brcmfmac4359-sdio.clm_blob brcmfmac54591-pcie.bin
BCM4345C5.hcd brcmfmac43241b5-sdio.bin brcmfmac43430-sdio.bin brcmfmac43455-sdio.txt brcmfmac4356-pcie.clm_blob brcmfmac43602-pcie.ap.bin brcmfmac54591-pcie.clm_blob
bcm43xx-0.fw brcmfmac43242a.bin brcmfmac43430-sdio.clm_blob brcmfmac43456-sdio.bin brcmfmac4356-sdio.bin brcmfmac43602-pcie.bin brcmfmac89459-pcie.bin
bcm43xx_hdr-0.fw brcmfmac4329-sdio.bin brcmfmac43430-sdio.txt brcmfmac43456-sdio.clm_blob brcmfmac4356-sdio.clm_blob brcmfmac4366b-pcie.bin brcmfmac89459-pcie.clm_blob
brcmfmac43012-sdio.bin brcmfmac4330-sdio.bin brcmfmac43436-sdio.bin brcmfmac43456-sdio.txt brcmfmac43570-pcie.bin brcmfmac4371-pcie.bin LICENCE
brcmfmac43012-sdio.clm_blob brcmfmac43340-sdio.bin brcmfmac43436-sdio.clm_blob brcmfmac4350c2-pcie.bin brcmfmac43570-pcie.clm_blob brcmfmac4373.bin README
brcmfmac43143.bin brcmfmac4334-sdio.bin brcmfmac43436-sdio.txt brcmfmac4350-pcie.bin brcmfmac4358-pcie.bin brcmfmac4373.clm_blob versions
brcmfmac43143-sdio.bin brcmfmac4335-sdio.bin brcmfmac43436s-sdio.bin brcmfmac4354-sdio.bin brcmfmac4359-pcie.bin brcmfmac4373-sdio.bin
Please give me solution how to fix the issue ralated to "/wl: wl driver adapter not found
With best regards,
Thank you very much!!!!!!!!!!
Wi-Fi Bluetooth for Linux
- FCC Test Tool
Hi @trongbang108 ,
You can request MFG firmware from the module maker (I think it is Muarata in the case of RPI module) or you can create a case here :
Hi @trongbang108 ,
Do you see the wlan0 interface when you run command "ifconfig"?
Can you try running "ifconfig wlan0 up"?
thank you for your response, I changed to another wl version
pi@raspberrypi:~/wlfmac $ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11 Mode:Master Tx-Power=19 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
pi@raspberrypi:~/wlfmac $ sudo ./wlfmac1.28_arm64 ver
1.28 RC0.0
wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
pi@raspberrypi:~/wlfmac $ sudo ./wlfmac1.28_arm64 pkteng_start 00:11:22:33:44:55 tx 20 1500 0
./wlfmac1.28_arm64: error -23
It return -23
Hi @trongbang108 ,
You need to use manufacturing test firmware to run the pkteng command.
I cannot share the firmware in the community so you can create a case in mycases to request the testing firmware.
Hi @trongbang108 ,
oke
