firmware for 43456 chip (Pinebook Pro)
rathann
Is there any publicly available official firmware for the SDIO-based chip 43456 found in e.g. Pinebook Pro? There is a firmware distributed by Manjaro at https://gitlab.manjaro.org/tsys/pinebook-firmware/-/tree/master/brcm , but there's no information about its origin and it's crashing often with 5.11.x kernel on Fedora 34. I opened an issue on Github in the firmware repo, too: https://github.com/cypresssemiconductorco/ifx-linux-firmware/issues/1 .
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
As mentioned just a few hours back in the github "the 43456 chip is owned by Broadcom, so I think you can get in touch with them.
BCM43456-product link"
Roy Liu
DS_Lin
Distributor - Zenitron(GC)
First comment on blog 100 sign-ins 50 replies posted
Hi Rathann,
Which wifi driver are you using? dhd /fmac?
Br,
DS
rathann
Thanks for the quck reply! I'm using the brcmfmac driver .
DS_Lin
Hi Rathann,
Could you create MyCase technical support?
Then ask to provide  FW for brcmfmac on CYW43456
Is your feature request related to a problem? Please describe.
Official brcmfmac firmware for 43456 chip is missing. There are some firmwares for this chip floating around the internet, but their origin is unknown and it's crashing the kernel (5.11.12).
Describe the solution you'd like
I'd like Cypress to submit official firmware for this chip to Linux kernel upstream or at least provide it here under a redistributable license so that it can be included in Linux distributions like Fedora.
Describe alternatives you've considered
Swapping a different Wi-Fi chip would be alternative, but it'd be best if the Wi-Fi in the Pinebook Pro worked out-of-the-box.
1. Please visit MyCases site below.
https://www.cypress.com/mycases
2.Please select MyCases
3.Please select Technical Support, then you can create new MyCases.
If your account does not has Technical Support,
please report it on following link.
https://www.cypress.com/webform/website-support
Br,
DS
rathann
My newly created account doesn't seem to have access to Technical Support. I sent the request via https://www.cypress.com/webform/website-support , thanks.
DS_Lin
Hi Rathann,
I'm really sorry,we do not support BCM43456 from Broadcom, it should be please contact your infineon Sales/Field representative if you have any questions or if there is anything else we can help you with.
Br,
DS
rathann
Sorry to hear that, but thanks for the quick response.
DS_Lin
Hi Rathann,
We do not support BCM43456 from Broadcom ,TKS!
Br,
DS
Roy_Liu
Roy Liu
