The defaule value of PCM clock is 512KHz, but we want to set 128KHz, so I config cyw43438 as follows:
1, Write_I2SPCM_Interface_Param
[MiniBoard]# hcitool cmd 0x3f 0x6D 0x01 0x01 0x00 0x00
< HCI Command: ogf 0x3f, ocf 0x006d, plen 4
01 01 00 00
> HCI Event: 0x0e plen 4
01 6D FC 00
2, Write_SCO_PCM_Int_Param
[MiniBoard]# hcitool cmd 0x3f 0x1C 0x00 0x00 0x00 0x01 0x01
< HCI Command: ogf 0x3f, ocf 0x001c, plen 5
00 00 00 01 01
01 1C FC 00
3, Write_PCM_Data_Format_Param
[MiniBoard]# hcitool cmd 0x3f 0x1E 0x00 0x00 0x03 0x03 0x01
< HCI Command: ogf 0x3f, ocf 0x001e, plen 5
00 00 03 03 01
01 1E FC 00
Then,I Read the cyw43438 config,
1, Read_SCO_PCM_Int_Param
[MiniBoard]# hcitool cmd 0x3f 0x1d
< HCI Command: ogf 0x3f, ocf 0x001d, plen 0
> HCI Event: 0x0e plen 9
01 1D FC 00 00 00 00 01 01
2, Read_PCM_Data_Format_Param
[MiniBoard]# hcitool cmd 0x3f 0x1f
< HCI Command: ogf 0x3f, ocf 0x001f, plen 0
01 1F FC 00 00 00 03 03 01
[MiniBoard]#
The PCM/SCO is configed successfully, but the PCM_CLK is still 512KHz when I mesaure the PCM_CLK signals with an oscilloscope.
What should I do so that I can config cyw43438's PCM_CLK work at 128KHz?
Hi Guang:
I check the input command from you, It is correct. and below description is for your reference:
8kHz sampling rate with 16 bits in each PCM sample requires minimum 128-bit PCM
clock rate to support one narrowband speech channel.
Bluetooth supports maximum 3 simultaneous SCO/eSCO channels.
Hi Guang:
