changes needed in Linux kernel to get WiFi+Bluetooth(CYW4343W) in life
paPr_4835046
Hi
our team has to build sama5d3_xplained based board currently we are stuck in the wifi+bt section.
we are using the "Cypress CYW4343W" chipset below link given.
link https://wireless.murata.com/type-1dx.html
We are using buildroot-at91 (https://github.com/linux4sam/buildroot-at91).
we try to integrate wifi+bt with SAMA5D3 but we do not get any solution.
now, what steps needed in the Linux kernel to get WiFi+Bluetooth in life.
thank you
It appears that you have used linux kernel version 5.4.81 whereas the FMAC release has been tested only up to kernel version 5.4.18.
GauravS_31
10 questions asked 250 solutions authored 250 sign-ins
You can consider compiling the latest FMAC driver https://community.cypress.com/docs/DOC-21490 and generate kernel modules which can be insmoded and the WLAN interface will be brought up. This was tested on kernel v5.4.18. You can follow the instructions in README to compile the driver and bring up WLAN interface.
Hi
I have downloaded and gone through README file.
also tried but having some issued, as I inform you we are using buildroot. and your suggestion are given on yocto.
So can you please provide any reference or guide for buildroot-at91 based systems.
Currently in Device yocto running (https://github.com/linux4sam/meta-atmel)
- Linux sama5d3-xplained-sd 5.4.81-linux4sam-2020.10-rc5
We are using FMAC driver (https://community.cypress.com/docs/DOC-21490 )
Followed all steps as written in README
Below Error given
CC   /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/compat/main.o
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/string_64.h:6:0,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/string.h:5,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/string.h:20,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/string.h:3,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/page_32.h:35,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/page.h:14,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/thread_info.h:12,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/thread_info.h:38,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/preempt.h:7,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/preempt.h:78,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/spinlock.h:51,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/spinlock.h:3,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/seqlock.h:36,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/time.h:6,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/time.h:3,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/stat.h:19,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/module.h:10,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/module.h:3,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/compat/main.c:1:
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/jump_label.h: In function ‘jump_entry_code’:
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/jump_label.h:149:14: error: dereferencing pointer to incomplete type ‘const struct jump_entry’
  return entry->code;
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/jump_label.h: In function ‘jump_entry_set_init’:
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/jump_label.h:176:7: error: dereferencing pointer to incomplete type ‘struct jump_entry’
  entry->key |= 2;
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/jump_label.h: At top level:
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/jump_label.h:208:26: error: array type has incomplete element type ‘struct jump_entry’
extern struct jump_entry __start___jump_table[];
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/jump_label.h:209:26: error: array type has incomplete element type ‘struct jump_entry’
extern struct jump_entry __stop___jump_table[];
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_types.h:346:0,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/processor.h:19,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/cpufeature.h:5,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/thread_info.h:53,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/pgtable-nopud.h:21:0: warning: "PUD_SHIFT" redefined
#define PUD_SHIFT P4D_SHIFT
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_types.h:249:0,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_64_types.h:83:0: note: this is the location of the previous definition
#define PUD_SHIFT 30
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/pgtable-nopud.h:22:0: warning: "PTRS_PER_PUD" redefined
#define PTRS_PER_PUD 1
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_64_types.h:84:0: note: this is the location of the previous definition
#define PTRS_PER_PUD 512
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/pgtable-nopud.h:23:0: warning: "PUD_SIZE" redefined
#define PUD_SIZE   (1UL << PUD_SHIFT)
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_64_types.h:100:0: note: this is the location of the previous definition
#define PUD_SIZE (_AC(1, UL) << PUD_SHIFT)
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/pgtable-nopud.h:24:0: warning: "PUD_MASK" redefined
#define PUD_MASK   (~(PUD_SIZE-1))
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_64_types.h:101:0: note: this is the location of the previous definition
#define PUD_MASK (~(PUD_SIZE - 1))
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_types.h:372:0,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/pgtable-nopmd.h:20:0: warning: "PMD_SHIFT" redefined
#define PMD_SHIFT PUD_SHIFT
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_64_types.h:90:0: note: this is the location of the previous definition
#define PMD_SHIFT 21
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/pgtable-nopmd.h:21:0: warning: "PTRS_PER_PMD" redefined
#define PTRS_PER_PMD 1
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_64_types.h:91:0: note: this is the location of the previous definition
#define PTRS_PER_PMD 512
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/pgtable-nopmd.h:22:0: warning: "PMD_SIZE" redefined
#define PMD_SIZE   (1UL << PMD_SHIFT)
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_64_types.h:98:0: note: this is the location of the previous definition
#define PMD_SIZE (_AC(1, UL) << PMD_SHIFT)
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/pgtable-nopmd.h:23:0: warning: "PMD_MASK" redefined
#define PMD_MASK   (~(PMD_SIZE-1))
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/pgtable_64_types.h:99:0: note: this is the location of the previous definition
#define PMD_MASK (~(PMD_SIZE - 1))
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic.h:262:0,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/asm/atomic.h:3,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic.h:7,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/atomic.h:3,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/cpumask.h:13,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/cpumask.h:5,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/msr.h:11,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/processor.h:21,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:20:44: error: unknown type name ‘atomic64_t’
static inline s64 arch_atomic64_read(const atomic64_t *v)
In file included from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/compiler.h:3:0,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/kernel.h:11,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/kernel.h:3,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/include/linux/list.h:9,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/list.h:3,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/module.h:9,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h: In function ‘arch_atomic64_read’:
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:22:22: error: request for member ‘counter’ in something not a structure or union
  return READ_ONCE((v)->counter);
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/compiler.h:261:17: note: in definition of macro ‘__READ_ONCE’
  union { typeof(x) __val; char __c[1]; } __u;   \
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:22:9: note: in expansion of macro ‘READ_ONCE’
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/compiler.h:263:22: note: in definition of macro ‘__READ_ONCE’
   __read_once_size(&(x), __u.__c, sizeof(x));  \
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/compiler.h:263:42: note: in definition of macro ‘__READ_ONCE’
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/compiler.h:265:30: note: in definition of macro ‘__READ_ONCE’
   __read_once_size_nocheck(&(x), __u.__c, sizeof(x)); \
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/compiler.h:265:50: note: in definition of macro ‘__READ_ONCE’
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h: At top level:
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:32:38: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline void arch_atomic64_set(atomic64_t *v, s64 i)
                                      atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:44:54: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static __always_inline void arch_atomic64_add(s64 i, atomic64_t *v)
                                                      atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:58:45: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline void arch_atomic64_sub(s64 i, atomic64_t *v)
                                             atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:74:54: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline bool arch_atomic64_sub_and_test(s64 i, atomic64_t *v)
                                                      atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:86:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static __always_inline void arch_atomic64_inc(atomic64_t *v)
                                               atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:100:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static __always_inline void arch_atomic64_dec(atomic64_t *v)
                                               atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:116:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline bool arch_atomic64_dec_and_test(atomic64_t *v)
                                               atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:130:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline bool arch_atomic64_inc_and_test(atomic64_t *v)
                                               atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:145:54: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline bool arch_atomic64_add_negative(s64 i, atomic64_t *v)
                                                      atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:158:60: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static __always_inline s64 arch_atomic64_add_return(s64 i, atomic64_t *v)
                                                            atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:163:51: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline s64 arch_atomic64_sub_return(s64 i, atomic64_t *v)
                                                   atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:168:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline s64 arch_atomic64_fetch_add(s64 i, atomic64_t *v)
                                                  atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:173:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline s64 arch_atomic64_fetch_sub(s64 i, atomic64_t *v)
                                                  atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:178:41: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline s64 arch_atomic64_cmpxchg(atomic64_t *v, s64 old, s64 new)
                                         atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:184:55: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static __always_inline bool arch_atomic64_try_cmpxchg(atomic64_t *v, s64 *old, s64 new)
                                                       atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:189:38: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline s64 arch_atomic64_xchg(atomic64_t *v, s64 new)
                                      atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:194:45: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline void arch_atomic64_and(s64 i, atomic64_t *v)
                                             atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:202:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline s64 arch_atomic64_fetch_and(s64 i, atomic64_t *v)
                                                  atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:211:44: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline void arch_atomic64_or(s64 i, atomic64_t *v)
                                            atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:219:49: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline s64 arch_atomic64_fetch_or(s64 i, atomic64_t *v)
                                                 atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:228:45: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline void arch_atomic64_xor(s64 i, atomic64_t *v)
                                             atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic64_64.h:236:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline s64 arch_atomic64_fetch_xor(s64 i, atomic64_t *v)
                                                  atomic_t
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/atomic.h:265:0,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:834:21: error: unknown type name ‘atomic64_t’
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:852:14: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
              atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:870:21: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                     atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:879:28: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                            atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:919:27: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                           atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:958:21: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                     atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:967:28: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                            atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1007:27: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                           atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1047:14: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
              atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1137:14: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
              atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1226:21: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                     atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1235:27: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                           atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1324:20: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                    atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1333:26: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                          atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1372:21: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                     atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1381:27: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                           atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1421:15: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_xchg(atomic64_t *v, s64 i)
               atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1461:18: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                  atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1501:22: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                      atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1545:30: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                              atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1555:23: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                       atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1565:23: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                       atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/atomic-instrumented.h:1575:30: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
                              atomic_t
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic.h:74:0,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1190:29: error: unknown type name ‘atomic64_t’
atomic64_read_acquire(const atomic64_t *v)
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/barrier.h:85:0,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/asm/barrier.h:7,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/compiler.h:256,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/compiler.h:3,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h: In function ‘atomic64_read_acquire’:
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1192:30: error: request for member ‘counter’ in something not a structure or union
  return smp_load_acquire(&(v)->counter);
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/barrier.h:186:10: note: in definition of macro ‘smp_load_acquire’
  typeof(*p) ___p1 = READ_ONCE(*p);    \
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/barrier.h:186:21: note: in expansion of macro ‘READ_ONCE’
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1192:9: note: in expansion of macro ‘smp_load_acquire’
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/compiler.h:330:9: note: in definition of macro ‘__compiletime_assert’
   if (!(condition))     \
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/compiler.h:350:2: note: in expansion of macro ‘_compiletime_assert’
  _compiletime_assert(condition, msg, __compiletime_assert_, __COUNTER__)
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/compiler.h:353:2: note: in expansion of macro ‘compiletime_assert’
  compiletime_assert(__native_word(t),    \
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/compiler.h:353:21: note: in expansion of macro ‘__native_word’
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/asm-generic/barrier.h:187:2: note: in expansion of macro ‘compiletime_assert_atomic_type’
  compiletime_assert_atomic_type(*p);    \
   if (!(condition))     \
   if (!(condition))     \
   if (!(condition))     \
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h: At top level:
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1199:22: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_set_release(atomic64_t *v, s64 i)
                      atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1392:21: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_inc_return(atomic64_t *v)
                     atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1401:29: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_inc_return_acquire(atomic64_t *v)
                             atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1410:29: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_inc_return_release(atomic64_t *v)
                             atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1419:29: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_inc_return_relaxed(atomic64_t *v)
                             atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1473:20: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_inc(atomic64_t *v)
                    atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1482:28: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_inc_acquire(atomic64_t *v)
                            atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1491:28: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_inc_release(atomic64_t *v)
                            atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1500:28: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_inc_relaxed(atomic64_t *v)
                            atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1563:21: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_dec_return(atomic64_t *v)
                     atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1572:29: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_dec_return_acquire(atomic64_t *v)
                             atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1581:29: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_dec_return_release(atomic64_t *v)
                             atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1590:29: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_dec_return_relaxed(atomic64_t *v)
                             atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1644:20: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_dec(atomic64_t *v)
                    atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1653:28: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_dec_acquire(atomic64_t *v)
                            atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1662:28: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_dec_release(atomic64_t *v)
                            atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1671:28: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_dec_relaxed(atomic64_t *v)
                            atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1760:24: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_andnot(s64 i, atomic64_t *v)
                        atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1776:30: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_andnot(s64 i, atomic64_t *v)
                              atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1785:38: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_andnot_acquire(s64 i, atomic64_t *v)
                                      atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1794:38: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_andnot_release(s64 i, atomic64_t *v)
                                      atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:1803:38: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_andnot_relaxed(s64 i, atomic64_t *v)
                                      atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:2194:27: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_fetch_add_unless(atomic64_t *v, s64 a, s64 u)
                           atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:2219:21: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_add_unless(atomic64_t *v, s64 a, s64 u)
                     atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:2235:23: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_inc_not_zero(atomic64_t *v)
                       atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:2244:30: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_inc_unless_negative(atomic64_t *v)
                              atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:2260:30: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_dec_unless_positive(atomic64_t *v)
                              atomic_t
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/atomic-fallback.h:2276:26: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
atomic64_dec_if_positive(atomic64_t *v)
                          atomic_t
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/cpufeature.h:5:0,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/processor.h:174:0: warning: "cache_line_size" redefined
#define cache_line_size() (boot_cpu_data.x86_cache_alignment)
In file included from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/cache.h:4:0,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/printk.h:9,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/printk.h:5,
                 from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/kernel.h:15,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/cache.h:79:0: note: this is the location of the previous definition
#define cache_line_size() L1_CACHE_BYTES
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/processor.h: In function ‘load_cr3’:
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/processor.h:243:12: error: implicit declaration of function ‘__sme_pa’; did you mean ‘__sme_clr’? [-Werror=implicit-function-declaration]
  write_cr3(__sme_pa(pgdir));
            __sme_clr
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/cache.h:6:0,
                 from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/cache.h:4,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/processor.h: At top level:
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/cache.h:8:25: error: ‘CONFIG_X86_L1_CACHE_SHIFT’ undeclared here (not in a function); did you mean ‘CONFIG_ARM_L1_CACHE_SHIFT’?
#define L1_CACHE_SHIFT (CONFIG_X86_L1_CACHE_SHIFT)
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/cache.h:9:30: note: in expansion of macro ‘L1_CACHE_SHIFT’
#define L1_CACHE_BYTES (1 << L1_CACHE_SHIFT)
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/cache.h:13:25: note: in expansion of macro ‘L1_CACHE_BYTES’
#define SMP_CACHE_BYTES L1_CACHE_BYTES
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/cache.h:35:58: note: in expansion of macro ‘SMP_CACHE_BYTES’
#define ____cacheline_aligned __attribute__((__aligned__(SMP_CACHE_BYTES)))
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/percpu-defs.h:148:2: note: in expansion of macro ‘____cacheline_aligned’
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/processor.h:425:1: note: in expansion of macro ‘DECLARE_PER_CPU_ALIGNED’
DECLARE_PER_CPU_ALIGNED(struct stack_canary, stack_canary);
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/preempt.h:7:0,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/thread_info.h:103:19: error: redefinition of ‘arch_within_stack_frames’
static inline int arch_within_stack_frames(const void * const stack,
In file included from /home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/thread_info.h:38:0,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/arch/x86/include/asm/thread_info.h:180:19: note: previous definition of ‘arch_within_stack_frames’ was here
In file included from /home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/backport-include/linux/spinlock.h:3:0,
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/include/linux/spinlock.h:60:10: fatal error: asm/mmiowb.h: No such file or directory
#include <asm/mmiowb.h>
cc1: some warnings being treated as errors
compilation terminated.
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/scripts/Makefile.build:265: recipe for target '/home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/compat/main.o' failed
make[6]: *** [/home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/compat/main.o] Error 1
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/scripts/Makefile.build:500: recipe for target '/home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/compat' failed
make[5]: *** [/home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports/compat] Error 2
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/Makefile:1729: recipe for target '/home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports' failed
make[4]: *** [/home/dnk025/Music/Project_PLC/cypress-fmac-v5.4.18-2020_0925/v5.4.18-backports] Error 2
/home/dnk025/testDir/poky/build-microchip/tmp/work-shared/sama5d3-xplained-sd/kernel-source/Makefile:179: recipe for target 'sub-make' failed
make[3]: *** [sub-make] Error 2
Makefile.build:13: recipe for target 'modules' failed
make[2]: *** [modules] Error 2
Makefile.real:88: recipe for target 'modules' failed
make[1]: *** [modules] Error 2
Makefile:40: recipe for target 'modules' failed
make: *** [modules] Error 2
by study, the log I hope you understand the problem and provide me support
