Wi-Fi Bluetooth for Linux
AnUk_4605356
New Contributor
Hello . I wonder if Cypress  provide support for a2dp offload feature in Android  . The BT chip is 43455 . For now we use default configuration and sound transmitted to BT chip by UART . However audio is slightly choppy .
Thank you .
SheetalJ
Hi anuk_4605356​,
A2DP offload feature is not supported by default for CYW43455 chip.
However, the feature can be enabled in firmware, please get in touch with our marketing team for more support on this.
SheetalJ
Hi anuk_4605356​,
