daio8910
10 sign-ins First like given First reply posted
We would like to support WPA3 Enterprise and AES-192 modes by CYW4373 using murata Type 2BC.
Using bindings for Linux driver is as below for Infenion CYW4373.
https://github.com/STMicroelectronics/linux/blob/v6.1-stm32mp/Documentation/devicetree/bindings/net/...
Are all Enterprise security modes supported that are listed by wpa_supplicant here?
https://w1.fi/wpa_supplicant/
raks_99
First question asked 250 replies posted 250 sign-ins
Hi @daio8910 ,
Most of the EAP modes are supported in client mode. (As long as the security mode is enabled in the wpa_supplicant)
There is no list of supported modes that is available.
If you face issues using any security type, can you raise an issue.
raks_99
Hi @daio8910 ,
We don't support 192-bit mode on this device.
I will get back regarding the security modes that are supported.
daio8910
CYW4347 don't support 192-bits mode as AES-192 option.
Noted.
Sure. Looking forward to your response.
raks_99
Hi @daio8910 ,
Noted.
If we need using security type of the WPA-EAP modes in our client, we will raise an issue again.
