I need WL tool & MFG Firmware for ARM aarch64 Platform with Linux5.4.70 Kernel + iMX8MMini Processor Supported WL Tool.
Kindly provide the wl tool source & Build procedure document + MFG Firmware Build procedure Document.
How to build WL Tool + MFG Firmware in Yocto?
Thanks & Regards,
Kumaresan
Hi @Kumaresan,
You can get in touch with the Module vendor and request a custom clm blob with country code EU from them. Thanks.
Hi @Kumaresan , Please get in touch with your local Infineon sales office for the above request.
Hi Raks,
Is WL Tool Support EUROPE Country code?
In WL Tool Country list EUROPE Country code is not there.
can i get WL tool for aarch64 + mfg binaries
Can you provide procedure how to load mfg binaries?
Thanks and Regards,
Kumaresan G
Country support depends on the clm_blob. You can create a request to add a country code if you don't find it in your clm_blob.
WL tool has been shared there for aarch64/arm64.
MFG binary cannot be shared on the community.
Just replace the existing .bin file in /lib/firmware/cypress/ with the mfg binary and reload the driver.
Hi raks,
i need European Country code Supported WL Tool & clm blob file for RF testing [CyW43455 Chipset]
We are going to test ETSI Standard RF testing with CYW43455 Chipset + LBEE5HY1MW Wifi BT Murata Module.
Currently i am having wl tool + clm blob file European country code is not there.
Thanks & Rgards,
Kumaresan G
Hi @Kumaresan ,
You can set the country to Germany ("wl country DE") since it has the same limits as Europe.
If you need a country code such as "EU" then you will have to request another clm blob file
Hi raks,
Where i can request EU Supported clm blob file?
Can i get "EU" Country code Supported clm blob file in here
Thanks & Regards,
Kumaresan G
Hi @Kumaresan,
