Roam prof command on Embedded Artists board is not working/not supported:
fw version is : wl0: May 22 2020 21:24:34 version 7.45.214 (9c83742 CY) FWID 01-59feefd4.
The firmware which we have on our device is from yocto-release for embedded artists board. This is the repo : git://github.com/murata-wireless which is used in manifest file for meta-murata-wireless layer.
root@imx7ulpea-ucom:/etc/wpa_supplicant# wl roam_prof b 0 -65 -100 10, -65 20 10 120 20 1 100
Unable to get wlc_ver iovar -45.
I'm getting this error.
Tijana
Hi @tsaranovac ,
Looks like the roaming profile is set and active. The roaming should work as per the configuration that you've set.
Hi @raks_99
roam_prob I guess there's a typo and it should be roam_prof. With the roam_prof there's the output of the command:
root@imx7ulpea-ucom:~# wl roam_prof b
flag:ffffff80 RSSI[-75,-128] delta:20(dBm) boost:-65.by.0 nfscan:3 period(full:70s partial:10s.x1.10s)
Hi @tsaranovac ,
