We require your help for below commands to run for our Module certification.
WiFi:
- Packet Error Rate Calculation in Rx Blocking Mode Test
BT:
- Change Data Pattern: Require to send customized data pattern.
- Bit Rate Error Calculation for Rx Blocking Mode Test
- Modifying BT Tx Power: Commands to SET/GET Tx Power
BLE:
- Default Tx Power: Commands to SET/GET Tx Power
Here are the software version details:
WiFi Driver Version:
Loading modules backported from Linux version v4.14.52-manda-RTM-0-g897c6ce
Backport generated by backports.git v4.14-rc2-1-70-g694b78f
brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdio.bin for chip 0x004345(17221) rev 0x000006
usbcore: registered new interface driver brcmfmac
brcmfmac: brcmf_c_preinit_dcmds: Murata Customized Version: imx-rocko-manda_r1.0;
brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Sep 21 2018 04:08:34 version 7.45.173 (r707987 CY) FWID 01-d2799ea2
Wl Version:
1.21 RC0.0
Bluetooth Stack:
bluez5.46
Let us know if any more details are required.
Please find the attached archive. It contains the following:
02252016HCI Command_HCItool.xlsx: The commands for Bluetooth testing
wl_command_scripts: The script files for calculating bit error rate for Wi-Fi.
002-25347_AN225347_Cypress_Wi-Fi_CLM_Regulatory_Manual.pdf: Cypress regulatory document
CyBluetoolUser-Guide.pdf: CyBlueTool user guide
I hope these will help you solve your issue.
Romit
Could you please follow the document below.
New Document Release: AN225347 - Cypress Wi-Fi CLM Regulatory Manual
Can you please share the Commands for Bluetooth.
Romit
Thanks a lot RoCh_2868046.
Will go through the commands and update you.
