alenhsu
5 sign-ins First like received First reply posted
Dear Sir,
I am working Raspberry Pi 4/3, 64bits linux enabled project. I would need to perform wl command for FCC test. I found several topic about similar request, and I tried to submit a case for technical support to get mfg firmware. however, due to COVID-19, I could not submit the new case.
 May I have your support to have proper wl and mfg firmware for FCC test? Thanks.
Alen
https://community.cypress.com/t5/Wi-Fi-Bluetooth-for-Linux/wl-tool-version-for-Raspberry-Pi-4B-runni...
Alen
raks_99
250 replies posted 250 sign-ins 100 replies posted
Hi Alen,
Will share the firmware and tool in the case.
Rakshith
raks_99
Hi Alen,
Rakshith
Hi, I am looking for the wl tool and mfg firmware for fcc testing also. I have downloaded several versions of the wl tool from the forum for 32 and 64, but I have not been able to find the mfg firmware. Also, it looks like we can no longer open my-cases.
I can use any os: raspian-32, raspian-arm64 or ubuntu-arm64
Thanks!
raks_99
Hi Scott,
In case if you are using a 43455 module (A Murata module for example)  then the mfg firmware can be requested from the module vendor. If it is for the Raspberry Pi then let me know.
Hi Raskshith,
  Thank you for quick supporting. I got  firmware and tool, I can execute both in my system properly.
Alen
