Download the new Linux Driver
Download Now
Wi-Fi Bluetooth for Linux
YoTa_1693656
Level 6
250 replies posted 250 sign-ins 100 replies posted
Level 6
Hello, Infineon/Cypress team
[Issue]
We are evaluating below FMAC driver below to use CYW43455. The FMAC driver occurs memory leak.
https://community.cypress.com/docs/DOC-21490
[Test Procedure]
kernel version: 4.14.78
for i in `seq 1 100`
do
top -n 1
  insmod compat.ko
  insmod cfg80211.ko
  insmod brcmutil.ko
  insmod brcmfmac.ko
sleep 1
  rmmod brcmfmac
  rmmod brcmutil
  rmmod brcm80211
  rmmod cfg80211
  rmmod compat
done
[Consideration]
Under our investigation, we narrow down two suspected locations to cause a memory leak.
1)
<cypress-fmac-v5.4.18-2020_0925\v5.4.18-backportscompat\backport-genetlink.c>
Line 230:
ops = kzalloc(sizeof(*ops) * (family->n_ops + 1), GFP_KERNEL);
2)
"backport_x509_cert_parse" in compat.ko
[Need Help]
Can Cypress fix this memory leak phenomenon?
We are happy if Cypress(Infineon) provides us a fixed patch for the FMAC source code.
Yoshinori
GauravS_31
Moderator First comment on KBA 5 questions asked First question asked
We will investigate the memory leak phenomenon in the latest driver release. Thank you for sharing your observations. Did you use mallinfo to measure the memory consumption?
YoTa_1693656
Level 6
Level 6
Hello Gaurav-san
No, we did not. To measure it, we used the following feature included the Linux kernel.
$ make menuconfig
'-> Kernel hacking
->Kernel memory leak detector
->Simple test for the kernel memory leak detector
By the way, regarding 1), we guess the following additional code is necessary to fix.
int backport_genl_unregister_family(struct genl_family *family)
+ if (family->copy_ops) {
+ kfree(family->copy_ops);
How do you think?
Yoshinori
YoTa_1693656
Level 6
Level 6
Hello Gaurav-san
Regarding 1)
We resolved the memory leak by attachment patch at our site. please review the patch.
Regarding 2)
Under our investigation, the memory leak occurs at "backport_x509_cert_parse" object. The estimated amount is 128B.
If it's difficult to fix this issue, let me know that.
Yoshinori
YoTa_1693656
Level 6
Level 6
Hello Gaurav-san
Regarding 2)
We could fix the memory leak in "backport_x509_cert_parse" by attachment "free-X509_cert_parse-compat.patch".
Thus, now, our request is very simple. Could you review attachment patches?
(If you think those patches are no problem, I close this thread.)
Yoshinori
