I am using the raspberry pi compute module 4, and for testing and certification, there is a need for wl tools for raspberry. I downloaded the tool from a thread in the tech forum.
Since I am reaching the same problem with error code -23 and I need the MFG firmware does it's possible to provide it to me?
I am using 32 bit Raspberry OS.
Oleg
Wi-Fi Bluetooth for Linux
The mfg firmware cannot be shared with the community, can you create a case in mycases system?
Yes, I created a case in mycases system, I am not very sure that I created it the right way.
Anyways here is an screenshot what I am get once the case is created.
Best,
Oleg
Thanks, Oleg
Shared the firmware with you.
Thank you for your quick response and guidance.
Can you also point me to the wl tool and testing firmware documentation and/or installation guide, I am trying to find a way to disable the 5GHz band during the SAR testing?
Best,
Oleg
You can place the firmware in /lib/firmware/brcm/brcmfmacxx.bin or /lib/firmware/cypress/cyfmacxx.bin
Attached below is the wl tool for RPi.
For setting the band you can use 'wl band' command
wl band a - force use of 802.11a band
wl band b - force use of 802.11b band
I will share wl tool documentation over in the case.
Thank for help everything works perfectly
Best,
Oleg
And the very last question.
Does it's also possible to change the duty cycle switch wl tool, since I cannot find any point in wl tool docs?
Best,
Oleg
Could you tell which duty cycle are you trying to change? Are you talking about the packeteng_start command?
Yes exactly about the pkteng_start command
Best,
Oleg
Hi Oleg,
Here is the usage for pkteng_start
pkteng_start
wl pkteng_start 00:11:22:33:44:55 tx 100 1024 0
start packet engine tx usage: wl pkteng_start <xx:xx:xx:xx:xx:xx> <tx|txwithack> [(async)|sync |sync_unblk] [ipg] [len] [nframes] [src]
start packet engine rx usage: wl pkteng_start <xx:xx:xx:xx:xx:xx> <rx|rxwithack> [(async)|sync] [rxframes] [rxtimeout]
sync: synchronous mode
sync_unblk: synchronous unblock mode
ipg: inter packet gap in us
len: packet length
nframes: number of frames; 0 indicates continuous tx test
src: source mac address
rxframes: number of receive frames (sync mode only)
rxtimeout: maximum timout in msec (sync mode only)
The ipg field decides the micro seconds of gap between packet transmissions.
Thank you for your guidance, now it's clear
Best,
oleg
