LM832 CYW43438 driver error
AkBh_4566821
I am trying to attach LM832 to my raspberry pi compute module. However i am not able to attach or find it. I think it will not require external drivers.
I am able to detect mmc1 as module. But on driver load I get
$ sudo modprobe brcmfmac
$ sudo dmesg -c
[ 381.903893] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 381.907147] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 381.939494] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 381.940215] brcmfmac: brcmf_chip_cores_check: CPU core not detected
[ 381.940229] brcmfmac: brcmf_sdio_probe_attach: brcmf_chip_attach failed!
[ 381.940249] brcmfmac: brcmf_sdio_probe: brcmf_sdio_probe_attach failed
[ 381.940518] brcmfmac: brcmf_ops_sdio_probe: F2 error, probe failed -19...
[ 381.940808] usbcore: registered new interface driver brcmfmac
What can be cause of such problem?
VinayakS_26
100 replies posted 50 replies posted 25 replies posted
Hi AkBh_4566821
Could you check whether you have a  clm_blob in the directory where you have kept the firmware for the wlan chip.
Does ifconfig display a wireless interface?
Vinayak
VinayakS_26
Hi AkBh_4566821
Vinayak
