Dear Sir,
I find the CYW54591 datasheet as below but I do not know how to control BT_HOST_WAKE and BT_DEV_WAKE pins by HCI commands.
I used the "Enable_generic_Wake_on_BLE" command but BT_HOST_WAKE and BT_DEV_WAKE pins can not be changed.
Could you have any example to control the pins or any suggests.thanks.
B.R.
Bill
The BT_DEV_WAKE is a input pin which is used for the host to wakeup the CYW54591. You need to configure the pin input and interrupt mode in your firmware.
The BT_HOST_WAKE is a output pin which is used for the CYW54591 to wakeup the host. You also need to configure the pin output mode and initial output level in your firmware. The host also need to configure the correspond pin and interrupt.
Dear Owen,
Our kernel is linux with kernel ver. 5.4.
Does the firmware refer to HDC file ?
B.R.
Bill
Yes, you need to check the HCD file for it.
Dear Owen,
Thank you for your prompt reply.
How to verify this functionality after hcd configure is done.
Below is our verify steps. Could you help to check it or provide SOP.
If it's not correct, could you help to modify it?
1.use "Configure_Sleep_Lines" to setup the BT_WAKE and HOST_WAKE sleep lines to different GPIOs and use those to test the wake up
2.use "Set_Sleepmode_Param"(0xFC27)
B.R.
Bill
