Wi-Fi Bluetooth for Linux Forum Discussions
Hrithik
5 replies posted 5 sign-ins First like given
Hi Infineon Team,
We need to conduct Pre compliance test on CYW43455 BT chip on Android 11 for which we need Hcitool.
Could you provide us hcitool for android 11 along with the integration document.
Hrithik
BragadeeshV
Moderator First question asked 1000 replies posted 750 replies posted
Hi @Hrithik
Which specific BT host stack are you using in Android OS? There should be similar tool such as hcitool or an API to send raw HCI commands to the controller. You need to check this with your host stack vendor.
Bragadeesh
Hrithik
Hi @BragadeeshV ,
We are using Infineon android vendor stack only for BT.
Hci commands do not work in adb shell as of now. Could you please help here?
Hrithik
BragadeeshV
Hi @Hrithik ,
Thanks for the update. Can you please let us know the name or the link  to the Infineon BT android stack and the version that you are using?
Bragadeesh
Hrithik
Hi @BragadeeshV ,
Actually, this whole patch/stack was provided to us in a personal case with Infineon team. Shall I share the entire folder here or in a private message if that is possible?
Hrithik
