Wi-Fi Bluetooth for Linux
user_3211541
New Contributor
Hi all,
I'm using a BCM43455 with driver bcmdhd v1.363.59.144.9 and I've been trying to get the wifi module in AP mode with two SSIDs. One SSID should be on 2.4GHz band and the other on 5GHz band. I've tried to get this working with hostapd but I haven't been successful.
Is this possible to achieve with this module?
Zhengbao_Zhang
hello:
    I don't think 43455 can create two APs in different band together in current release.  It should be a RSDB chip function.
Zhengbao_Zhang
hello:
user_3211541
New Contributor
Thanks for the clarification
