Wi-Fi Bluetooth for Linux
yasa_4608926
Contributor II
I am evaluating the FMAC driver using following.
- FMAC v4.14.77-2019_0503
- CYW4343W (SDIO Adapter)
- Laptop PC (Dell Latitude E6410, ubuntu)
I understand the recommended evaluation platform is MCIMX6SX-SDB,
but we need to evaluate using Laptop PC.
E6140 is an old model number, so it is difficult to obtain now.
I will to prepare a new evaluation environment using a relatively new model.
Is there a relatively new model in the recommended Laptop PC?
If it is none, please teach me the model number of the Laptop PC that has been used successfully.
Yasa
VinayakS_26
Just to confirm, what the interface that you are going to use to connect to the laptop PC? Is it SDIO ?
We haven't tried a port with a Laptop although theoretically, it is possible.
VinayakS_26
VinayakS_26
VinayakS_26
yasa_4608926
Contributor II
Thank you for your reply.
Yes, it is SDIO.
I am using SDIO to connect to the laptop PC (Dell Latitude E6410), it works fine.
Yasa
yasa_4608926
Contributor II
I looked for a laptop with SDIO I/F, but could not find almost it.
I understood that it was too little from the start.
Thank you for your help.
Yasa
