Hi Mohit,
Good. Can you confirm if you are using a module from a module vendor
If yes then they would have to provide you with the tool.
BR,
Rakshith
Hi Anurag ,
Welcome to the community. Sure I can help you with the wl tool. Can you tell me about the architecture of your host chip (32 or 64bit, arm or x86)?
BR,
Rakshith
Hi Anurag ,
Are you using a module from a module vendor? In that case, you can request the tool from them.
BR,
Rakshith
Hi Rakshith,
Thanks for replying. Our device architecture is aarch64 (64 bit). It has iMX8m mini processor.
Anurag and I are working in the same team.
BR,
Mohit
Hi Mohit,
BR,
Rakshith
