Package Version
v5.15.58-2022_1223
Release Date
2022-12-23
Description
This is Cypress's Linux brcmfmac driver and firmware support package.
Brcmfmac is an open-source driver project.
Files in this release:
* Backports package (cypress-backports-v5.15.58-2022_1223-module-src.tar.gz)
* Firmware/clm_blob files (cypress-firmware-v5.15.58-2022_1223.tar.gz)
* Cypress fmac patch files (cypress-patch-v5.15.58-2022_1223.zip)
* Device tree files (cypress-devicetree-2022-12-22.tar.gz)
* hostapd/wpa_supplicant patch (cypress-hostap_2_10-2022_1223.tar.gz)
* Cirrent Agent (cypress-cirrent-1.60.tar.gz)
* README
abe7f11b4379f60734436203fc4abea7bdd7fa2256835c14db69bbe6fe703699 cypress-backports-v5.15.58-2022_1223-module-src.zip
cdf9039c11f8feaead6ae736c14687c70e2feaccb7b081ef9b6a86dc487b1bb6 cypress-cirrent.zip
34b69f1b668831619b1e6a8382dcdc774c52909f63d9045591f57266ebb1ed54 cypress-devicetree.zip
1fef7d1e8933395b58113e7e3d6967cf04ce7354fe8bfcb8021c72bed48beac0 cypress-firmware-v5.15.58-2022_1223.zip
29d5a063b64e5e90b51c9e55902d4dd906d380d14f1fb7462e23a41ed7c67c80 cypress-fmac-v5.15.58-2022_1223.zip
835e2fdc923a68b3684ed77d0679029d958a377333c7bb8d9e9ba9c134905447 cypress-hostap_2_10-2022_1223.zip
f8cc4882c235d844f4cc1c54e1c3a4e3cfe7dfca9de840daea4d0b6cfcf61ebe cypress-patch-v5.15.58-2022_1223.zip
[Change Log]
2022-12-23 Initial Post
In the "Package Version" section specified "v5.10.9-2022_1223".
But file names include v5.15.58-2022_1223.
So, what is the correct version is v5.10.9 or v5.15.58?
Thank you the typo has been corrected.
Could the post be updated to have the correct checksums and filenames for the release package? Such that it is consistent with previous releases?
Hi, Could you please let us know if you have seen any mismatch in the release package please let us know the file name?
There's the "mrproper" target in the v5.15.58-backports/Makefile.
But it doesn't remove all generated files.
These files still present after doing "make ... mrproper":
compat/oid_registry_data.c
kconf/zconf.lex.c
kconf/zconf.tab.c
.config.old
Hi @Serhii_Purik,
Thank you for the query could you please create a new query or a Support case? This will help us to track the issue better
Vivek.
