owrp_4560236
Hello.
We are trying to prepare Wi-Fi software test for the reference lab to certificate our device.( Linux machine)
Our Communication Module uses a CYW43455 Cypress Module,
we found out in our researches this package Cypress Linux WiFi Driver , is it the right package that includes the Certtification Firmware and the tool "wl" ?
Cypress Linux WiFi Driver Release (FMAC) [2019-10-31]
update one for your test, not sure if your project can work well with this one.
Zhengbao_Zhang
250 sign-ins First comment on KBA 10 questions asked
I have check the release , we just release a normal firmware and clm for 43455,  so it is better to get help from distributor, module maker , or evb maker for the right nvram and test firmware, thanks.
thanks for your reply,
You said "it is better to get help from distributor, module maker " , Do you mean cypress ?
No, you will need to work with the module partner you selected, they will work with you to fine-tune parameters, the file will be used for RF test before releasing to their customers.
