Hi All,
We are using brcm4356 chip on Xilinx and we are seeing the below errors. We use wifi AP mode, and use iperf to test Throughput.
Could you give me some help from Cypress?
[ 510.737166] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block read failed -84
[ 510.748943] brcmfmac: brcmf_sdio_rxglom: glom read of 2560 bytes failed: -5
[ 510.794849] brcmfmac: brcmf_sdio_rxfail: abort command, terminate frame
[ 510.801628] brcmfmac: brcmf_sdio_hdparse: HW header length too long
[ 510.807916] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 510.813509] brcmfmac: brcmf_sdio_hdparse: Glom descriptor found in superframe head
[ 510.821091] brcmfmac: brcmf_sdio_rxfail: abort command, terminate frame
[ 510.827966] brcmfmac: brcmf_sdio_readframes: brcmf_sdio_readframes: glom superframe w/o descriptor!
[ 510.837025] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 510.883687] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block read failed -84
Wi-Fi Bluetooth for Linux
- cyw4356
We do not support BCM4356 from Broadcom. We support CYW4356. Please clarify whether this is a Cypress CYW4356 chip.
Hi John,
Your Cypress FMAC driver Cypress Linux WiFi Driver Release (FMAC) [2020-09-25] Yes?/No?
and LINUX version? Also your chip using brcm4356 chip?
Hi DS_Lin,
My linux version is 4.14.0, so I use cypress-fmac-v4.14.52-2018_0928 driver. And our chip is brcm4356s(sdio interface).
