Wi-Fi Bluetooth for Linux Forum Discussions
ribec_4322136
I was reading the thread BLE tx output power control in HCI mode and tested the proposed HCI_VENDOR_SET_TX_PWR command (0x01A5) on a chipset based on CYW4343W. However, it seems such command is not recognized/supported as per the logs I captured:
Therefore, my next question would be: is there any other specific command for this specific chipset that I may try to set the Tx power during a BLE advertising event?
According to the CYW4343W specification, it seems Bluetooth power control steps are available:
Ricardo Bello
Hi Ricardo,
The output power level for BLE is fixed; It is set to 4dBm for adv packets. There is no way to change the advertising tx power.
The vendor specific command you referred in description is specific for PSoC devices.
You can read the tx_power using CyBluetool (Windows Installer) command: LE_Read_Advertising_Channel_Tx_Power
SheetalJ
Hi Ricardo,
Can you let us know exactly which eval board or module you are using?
We are using a module provided by LSR Model Sterling-LWB part number 450-0152
Ricardo Bello
Hi Ricardo,
Hi SheetalJ_96
We usually have this command available from other Bluetooth hardware and vendors, so learning this level is fixed in this case is quite unexpected. Anyway, thank you for your reply. We are already using the LE_Read_Advertising_Channel_Tx_Power command in our implementation and we are consistently getting a value of 12dBm for this specific board.
Ricardo Bello
