Hi all,
I am using a Wifi/BT module containing CYW43438 connected to a RPI3CM. Wifi Works fine, BT no.
I connected only Rx TX to RPI and starting hciattach on raspbian it goes in timeout:
hciattach /dev/ttyAMA0 bcm43xx-3wire 115200 noflow -
bcm43xx_init
Initialization timed out.
On the module RTS is float CTS is pulldown.
Looking at the signals and decoding them, I see that the chip reply to the first command but not to the second one asking the chip name.
0x01 0x03 0x0C 0x00 <-- reset chip
0x04 0x0E 0x04 0x01 0x03 0x0C 0x00
0x01 0x14 0x0C 0x00 <-- asking for chip name
-- no answer
Can you help me to understand why the communication doesn't continue in order to setup the device completely?
Linux raspberrypi 4.14.68-v7+
bluez/stable,now 5.43-2+rpt2+deb9u2
bluez-firmware/stable,now 1.2-3+rpt6
pi-bluetooth/stable,now 0.1.9
My impression is that H% 3wire uart it is not properly configured and the chip look at the CTS signal anyway.
If I remove the pulldown on CTS, disappear also the fir reply to the reset command. So it seems the chip take the CTS status into account.
But I would like to use it managing only Rx and TX
Mimmo
Could you please confirm which UART are using? the miniUart or the main PL011 uart (https://www.raspberrypi.org/documentation/configuration/uart.md) ?
If the miniUart it probably won't work.
Secondly, i'd suggest trying it with CTS and RTS connected, as this is how it is configured on Pi3, Pi3B+, Pi0W
Let us know if these changes make any difference.
