Bringup problem in imx8qxp-mek yocto linux 5.10.35 with CYW88373
jungsikshin
I try to connect a module using CYW88373 to imx8qxp-mek using sdio.
Operation of the same module was successful in imx6ul-14x14.
However, there is no wifi-related part in the dts setting of imx8qxp-mek.
Which dts setting can be added to make it work at imx8qxp-mek?
Or, CYW88373 doesn't  support kernel 5.10.35?
kernel git is this: git://source.codeaurora.org/external/imx/linux-imx.git (HEAD: lf-5.10.y tag: lf-5.10.35-2.0.0)
imx6ul-14x14 defconfig: arch/arm/configs/imx_v7_defconfig
imx6ul-14x14 dts: imx6ul-14x14-evk-btwifi.dts (work well)
imx8qxp-mek defconfig: arch/arm64/configs/imx_v8_defconfig
imx8qxp-mek dts: imx8qxp-mek.dts
Zhengbao_Zhang
250 sign-ins First comment on KBA 10 questions asked
Hello:
  89373 will not be supported here,  please get local support to ask for official driver release and support for kernel 5.10.35.
jungsikshin
attach the error log
Zhengbao_Zhang
Hello:
