I want to port driver for CYW43455. I used this Cypress Linux WiFi Driver Release (FMAC) [2020-06-25] release. I need to port this driver for 4.9 kernel. I followed the instructions in README file given in the backports. During the cross compilation of modules, I have seen the following warning.
WARNING: "hash_algo_name" [/Downloads/cypress/v5.4.18-backports/compat/compat.ko] undefined!
Similarly, during insmod compat.ko in the target board. I got the following error:
sakthi@localhost:~$ sudo insmod compat.ko
insmod: ERROR: could not insert module compat.ko: Unknown symbol in module
In dmesg, I got the following logs after insmod of compat.ko,
[ 627.941252] compat: loading out-of-tree module taints kernel.
[ 627.949143] compat: Unknown symbol hash_algo_name (err 0)
Could you please let me know how to fix this issue?
Sakthi
- backport
"hash_algo_name" is implemented in the Linux Kernel source code "crypto/hash_info.c".
To use it, you need CONFIG_CRYPTO_HASH_INFO=y in your kernel configuration.
Please refer the README in FMAC package.
For FMAC, you need to enable the following in the kernel configuration.
#4. Enable below configs in .config
# CONFIG_ASYMMETRIC_KEY_TYPE=y
# CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
# CONFIG_X509_CERTIFICATE_PARSER=y
# CONFIG_PKCS7_MESSAGE_PARSER=y
If CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y, CONFIG_CRYPTO_HASH_INFO will be enabled by the dependency.
Yasa
Yasa
