Hi
Is there any documentation on NVRam available parameters? I understand NVram is to configure WiFi for best performance. And every module supplier has different NVRam parameters value.
I would like to know what is available to configure, not the value for each parameter.
Wi-Fi Bluetooth for Linux
Great. Thanks.
They have a section "NVRAM Content Development " and explained what is in the file.
AN215294 CYW4335 OTP Programming and NVRAM.pdf
Hi @mineronarrow,
Yes it is true that very module supplier has different NVRAM parameters value this is because NVRAM values are based on venders hardware configurations and performance tuning.
Q)I would like to know what is available to configure, not the value for each parameter.
Hope the NVRAM documents in the link will be useful -> https://www.cypress.com/search-results?as_q=NVRAM you could choose the appropriate document based on the WiFi/BT module.
If you are looking for any performance related issues you could contact your module vendor for more information
Great. Thanks.
