2 PC respectively connect 2 module method
Peggy
Distributor - Weikeng(GC)
10 questions asked 25 sign-ins 10 replies posted
Hi all,
I'm trying to use 2 PC respectively connect my 2 module to test throughput, but I don't know how the command to connect 2 PC.I found command for only one PC in the document. Attachment is  what I have tried.Please give me some suggestion. Thanks!
AnjanaM_61
Hello @Peggy ,
Sorry for the late response.
CYW20704 is not supported through community since we do not promote it to the broad market.
Please reach out to your local Cypress Sales/Distribution team, they should be able to help for 20704 specific issues.
Anjana
AnjanaM_61
Hello @Peggy
Can you please confirm which BT/BLE chip you are using?
As per my knowledge , Throughput test in CyBluetool can be used to evaluate throughput of one to one connection, not multiple connections.
Anjana
Peggy
Hi Anjana,
Thanks for your reply.
I am using CYW20704.
I use 2 PC is to test throughput of the distance can be extended. Do you have any other suggestions?
Peggy
AnjanaM_61
Hello @Peggy ,
Anjana
