AsAl_4421831
10 replies posted 10 sign-ins 5 replies posted
Hello Everyone,
My company is using Murata 1mw module in our product. Wifi connection drops/disconnects often. We are using the following firmware version for wifi  7.45.229 (617f1f5 CY) and the same issue is with  version 7.45.184 (r712131 CY)
The same issue has been discussed on RPI forum -
https://github.com/raspberrypi/linux/issues/3849#issuecomment-822341133
Is this a known issue? Can somebody please suggest the solution for it?
I have attached dmesg output, if any more logs are needed, please let me know.
Asma
AsAl_4421831
Hi @raks_99
I was able to solve that issue, by turning the roaming off in-kernel driver. It's a company's network, no idea how it is setup.
raks_99
First question asked 250 replies posted 250 sign-ins
Hi @AsAl_4421831 ,
Could you tell me more about how you are setting up the mesh? Also, it looks like you missed attaching the dmesg logs? I see some discussion in the Github issue, let me go through that as well.
AsAl_4421831
Hi @raks_99
