07:49 PM
Apr 18, 2017
07:49 PM
I mask the I2C setting and init in the An75779 demo code. compile , download in the Fx3 board. find the urb is sent(attch map)by hushound tool 。Can you give me some suggestion about the URB.
Rmark: my solution :two cmos sensor + fpga + cyusb3014. FPGA simulated the cmos sensor data in the test. So I
don't use the I2C 。in fact ,the cmos sensor setting is done by FPGA,no FX3。
Labels
11:06 PM
Apr 18, 2017
11:06 PM
o,this is my setting bushound error. urb is ok。but I find the length of the last packet can be change.can you tell me?
09:57 PM
May 08, 2017
09:57 PM
zhouhuaguo,
UVC header in the last packet of length 15924 bytes indicates that it is an EOF (End of Frame) packet.
Normally, the short packet comes only at the End of Frame.
