I am trying to integrate UVC application with another application.
It is throwing the following error. "No streaming interface found for terminal 4"
But the linux system recognises the uvc camera and enumerates it. Have attached screenshot and descriptor file.
What might be the reason for this?
I have also attached my USB descriptor file.
P.S I have commented out usb2,usb1 descriptor to make things simpler. I am using a computer with USB3 so it is not a problem.
I have solved the previous issue, but I am getting another error. The UVC is enumerated but is available at /dev/video0. VLC is throwing me the following error. "Invalid PCR value is ES_OUT_SET_(GROUP_)PCR |" How can I solve this?
Can you share your firmware? Which firmware did you use as the base?
Did you try any other applications apart from VLC? Yavta or QtCam ?
Savan
