usb 1.1 issue
JaVa_2104626
5 replies posted Welcome! 5 questions asked
hi,
     I wanted to usb USB full speed mode,the wMaxPacketSize in the device descriptor was set 8bytes.Now please give me some support which firmware can choose.
You can use CyU3PConnectState() API to force FX3 to enumerate as a HS device. Now, you need to connect a FS host to force FX3 into FS mode. wMaxPacketSize can be set to 8 bytes in the CyFxUSBFSConfigDscr[] for FS device.
You can take USBBulkSourceSink example project as a reference.
