Aug 15, 2018
02:10 AM
Aug 15, 2018
02:10 AM
I've a problem that the output frame rate of cx3 usb only half of the input.
The sensor's VS is 30Hz.
The VSYNC_TEST in cx3 is 30Hz.
I can get correct image frames from USB but the frame rate is only 15Hz.
I measure a gpio that toggle in the callback function of GPIF while get the event "CYU3P_GPIF_EVT_SM_INTERRUPT".
The frequence is 7.5Hz. That means the frequence of this event is 15Hz.
What is the cause of this problem?
Lee
03:30 AM
Aug 17, 2018
03:30 AM
Hi Hemanth,
Thanks for your reply.
This problem has been solved after extend the pulse width of VSYNC in sensor around to 250us.
Is there any requirement about the pulse width of VSYNC for CX3?
Lee
