subk1234
5 questions asked First like given 5 sign-ins
 I am using the CX3 Denebola board and using the EZ-USB FX3 SDK.
 When I used sprintf() calls in the code to print floating point values, I was getting an error saying _sbrk not found. I looked up the note https://community.infineon.com/t5/Knowledge-Base-Articles/Printing-Floating-Values-using-FX3-SDK-KBA...
  and made the necessary changes.
After these changes, I get the following error. What do I need to do to resolve this issue?
../calls.c: In function '_sbrk':
../calls.c:14:29: error: '__heap_start' undeclared (first use in this function)
heap_end = (char *)&__heap_start;
../calls.c:14:29: note: each undeclared identifier is reported only once for each function it appears in
../calls.c:18:28: error: '__heap_end' undeclared (first use in this function)
if (heap_end + incr > &__heap_end)
../cycx3_uvc.c:2636:29: note: each undeclared identifier is reported only once for each function it appears in
../cycx3_uvc.c:2640:28: error: '__heap_end' undeclared (first use in this function)
Thanks and Regards,
Subbu
Rashi_Vatsa
Moderator 500 solutions authored 1000 replies posted 750 replies posted
Please let me know if you have made the changes as done in USBBulkSrcSink firmware shared with the KBA and used same cyfxtx and .ld file
Rashi
Rashi_Vatsa
Rashi
subk1234
Hi Rashi,
Thank you for the quick response. I copied the files again correctly and it's working now.
I am able to using sprintf now.
Thanks and Regards,
Subbu
