In my usb2.0 host firmware test, I found something weird.
These are some code snippets and the resulting logs.
static void
CyFxHostXferCb (uint8_t ep, CyU3PUsbHostEpStatus_t epStatus)
CyU3PReturnStatus_t status = CY_U3P_SUCCESS;
CyU3PDebugPrint (4, "CyFxHostXferCb ep=0x%x epStatus=0x%x\r\n",ep,epStatus);
/* Queue the next request */
if (ep != 0)
status = CyU3PUsbHostEpSetXfer (ep, CY_U3P_USB_HOST_EPXFER_NORMAL, 0);
CyU3PDebugPrint (4, "CyFxHostXferCb CyU3PUsbHostEpSetXfer(0) status=0x%x\r\n",status);
/* This function initializes the USB host stack. */
void
CyFxUsbHostStart ()
CyU3PUsbHostConfig_t hostCfg;
CyU3PReturnStatus_t status;
hostCfg.ep0LowLevelControl = CyFalse;
hostCfg.eventCb = CyFxHostEventCb;
hostCfg.xferCb = CyFxHostXferCb;
status = CyU3PUsbHostStart (&hostCfg);
if (status != CY_U3P_SUCCESS)
return;
CyFxHostXferCb CyU3PUsbHostEpSetXfer(0) status=0x0
CyFxHostXferCb ep=0x81 epStatus=0x40
CyFxHostXferCb ep=0x81 epStatus=0x141
According to the following table, the last 4digits(3:0) indicate ep number.
When we look at the logs,
as we know, ep=0x81 means EP_NUM=1
CyFxHostXferCb ep=0x81 epStatus=0x141 -> This makes sense because, EP_NUM of epStatus is "1"
But in the following case,
CyFxHostXferCb ep=0x81 epStatus=0x40 -> epStatus tells EP_NUM is "0" instead of "1", which does not match with ep=0x81.
How should I interpret this discrepancy?
Rossi
USB Superspeed Peripherals
Please confirm if the behavior is same when CyU3PDebuPrint is not called in the interrupt callback
Rashi
Rashi
