DiMo_4607246
First like given
I am using FX3S - FPGA DEVELOPMENT KIT by Pactron Store.  I have downloaded the fx3 slave fifo interface example from cypress website( application note AN65974).
I tested this example with fx3 and cyclone 4 fpga. Its working fine.
I tried to do with the FX3s , I am seeing failed transactions in streamer application. I used same firmware. I do necessaery Fpga pin mapping for fx3s.
But gpif2usb example is working on fx3s.
Why slave sync fifo example is not working with fx3s ?
I am using 16bit gpif and I am testing streaming In application from slave fifo interface application.
Thank You
JayakrishnaT_76
I find that you have already created a thread asking the same question before. The link to the thread that was created before is given below:
Data transfer from FPGA to FX3s
Please carry on the discussions in the thread created before.
Jayakrishna
Jayakrishna
JayakrishnaT_76
Jayakrishna
Jayakrishna
