Hi I am generating pwm duty cycle with cx3 chip
previously i used complexupdate api it has some proble its not reflecting the values
Then i accessed register for updating the threshold value every time i changed the duty cycle the problem is when duty cycle changed to 100 perc its reflecting in dso as 50 percent can any one have idea on it
Thanks in advance
Best Regards
Clinton
Hi Clinton,
Could you let us know if the duty cycle is 100% if the complexUpdate API is used?
What is the implementation to access and change the register values? Please share code snippet.
AliAsgar
if((wIndex == 0x200) && (wValue == 0x200))/*FREQUENCY IN HZ*/
switch(bRequest)
case CX3_USB_UVC_GET_INFO_REQ:
glGet_Info=0x03;
status = CyU3PUsbSendEP0Data(1,&glGet_Info);
if (status != CY_U3P_SUCCESS)
CyU3PDebugPrint (4, "\n\r cx3 rdk sendendpoint0 fail = %d", status);
break;
case CX3_USB_UVC_GET_MIN_REQ:
gl16GetControl=1;
status = CyU3PUsbSendEP0Data(2,(uint8_t*)&gl16GetControl);
break;
case CX3_USB_UVC_GET_MAX_REQ:
gl16GetControl=10;
break;
case CX3_USB_UVC_GET_RES_REQ:
gl16GetControl=1;
break;
case CX3_USB_UVC_GET_CUR_REQ:
case CX3_USB_UVC_GET_DEF_REQ:
gl16GetControl=glfrequency;
CyU3PDebugPrint (4, "\n\rUSB Cx3 rdk StpCB:VCI SendEP0Data = %d", status);
break;
case CX3_USB_UVC_SET_CUR_REQ:
status = CyU3PUsbGetEP0Data(16,(uint8_t*)&gl16SetControl,&readCount);
glfrequency = (uint8_t)gl16SetControl;
frequency_ticks = CY_FX_PWM_PERIOD/(glfrequency);
- threshold_ticks = (frequency_ticks * gldutycycle/100);
gpioConfig.period= frequency_ticks;
gpioConfig.threshold = threshold_ticks;
HI @AliAsgar
I want to change from complex to simplex and vice versa in order to solve for 0 percent duty cycle its should blank in dso but actually its not
So in cx3 there is proble if we generate a pwm wave with 100 perc and 0 perc its comming around 50 %dutycycle if eventhough i hardcoded for 0 percent duty cycle its comming around 50 perc
clinton
Hi @AliAsgar I am attaching the file i share the password through privtae mode
for generating the duty cycle of 0 and 100 percent i used overide gpio function for zero percent duty cycle i set it too low the gpio and for 100 i set to high the gpio still when i do like that for 100 its showing 99% and for zero its showing 1%
BestRegards
clinton
