Jan 07, 2023
05:22 AM
Jan 07, 2023
05:22 AM
Hi
we are using CYUSB3035
i have build Fx3 firmware example from AN65974, build is done
but after putting .img file in FX3(sram), FX3 does not enumerate/ detect
but if we use .img file available in folder its works fine.
same with AN65974
11:04 PM
Jan 08, 2023
11:04 PM
Actually, the same query is discussed on another thread so you can follow up on that thread.
Please refer to the thread link:
https://community.infineon.com/t5/USB-superspeed-peripherals/need-help-on-fx3-firmware/td-p/391519
Sakshi Bakal
