WaRa_4824346
10 questions asked 10 sign-ins 5 replies posted
Parameter "int errno" on line 74 of main.cpp conflicts with typical C++ usage resulting in compilation errors.
Changing "errno" to "errnum" and adjusting the remainder of "libusb_error" to use "errnum" fixes the build problem.   After the suggested change, cyusb_linux build and runs.
Modified source code for "libusb_error" is attached.
Rashi_Vatsa
Thank you for the suggestion.
Please refer to  threads with similar fix Solved: EZ-USB-FX3 SDK for Linux fails to compile - Cypress Developer Community
Solved: Error compiling cyusb_linux_1.0.5 on Ubuntu 18.04 ... - Cypress Developer Community
We will forward this to the respective team.
Rashi
Rashi_Vatsa
Rashi
