TeLe_4638221
First like given
I had a question about fx3..
Is it possible that fx3 can be used by i2c slave mode?
if it is possible, how to set the fx3 firmware ? like i2c slave addr..
please let me know about that.
thanks
Ted Lee
Hemanth
First like given First question asked 750 replies posted
Hi Ted Lee,
No. Master/Slave option in the GPIF II Designer is for GPIF Interface and not for I2C.
Hemanth
Hemanth
JayakrishnaT_76
It is not possible to use FX3 as an I2C slave. The same is documented in page 31 section 1.4.6 of the document FX3 TRM. This document comes along with FX3 SDK and can be found in the following location:
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\doc\firmware
Jayakrishna
Jayakrishna
hello,
I though that I just can be possible to change the interface type from master to slave in the GPIF II designer.
thanks for your reply.
Ted Lee
Hemanth
Hi Ted Lee,
Hemanth
Hemanth
thanks for your support
Ted Lee
