hello everyone,
We are doing slavefifo intrface with the Fpga ,we want add the UVC Class . our requirement is to keep the UVC Class To fetch data from FPGA And one end point which is bulk OUt(for sending the data from pc to fx3) in the Control center .
can any one did this please help me .
best regards
veerendra
Hello Veerendra,
I have attached the modified descriptor file and the uvc.c file for endpoint handling. I have created a DMA channel between USB and CPU and discarded the buffer as it is received. You can modify this to suit your application.
For the first time, the vendor interface comes under 'Unknown Devices' section and the device should be manually bound to CYUSB3 driver.
Srinath S
