juhu_4653696
25 replies posted 10 replies posted 10 sign-ins
Dear,
We use EZ-USB FX3 UVC cyusb3014, Source code is base the "AN75779 project.
We want to change bulk mode to isochronous, but failed. Could you help us to set it?
Thank you very much!
Attachment is our code.
Jun
Rashi_Vatsa
Please find the attached AN75779 project which modified to stream using the Isochronous endpoint.
The macro USE_ISOCHRONOUS_ENDPOINT needs to be enabled to enable the isochronous endpoint. We have tested the firmware on WIn 10 PC (results attached)
Note: The changes are only done to add an isochronous endpoint in SusperSpeed configuration descriptors
Please modify the custom firmware based on this firmware
Rashi
Rashi
Rashi_Vatsa
Rashi
Rashi
Hi Rashi,
Apprecate for your reply! We will test later.
RR,
Jun
