Hi team,
I'm using cypress fx3 to stream a static test pattern as video to vlc, to check for sharpness and greyscales. The format is yuv 422, y:u:y:v (yuy2) as detected by vlc codec information tab, and res is 640x480 at 60fps.
The problem i face is as follows, the video displayed by the vlc is stable(not losing sync) but it is not sharp at the edges(ie. it lacks sharpness), but when i do a video->take snapshot in vlc, the image saved by vlc is same as the original test pattern sent.
Can any one please tell me what settings should i do in vlc to get video decoded properly. I have attached 3 images for ref, test_pattern_640 is the original image sent as video, snapshot the imgae obtained from vlc using vlc->take snapshot, snippet is the video screen captured using the snippet tool while video is playing on vlc.
-Thanks
USB Superspeed Peripherals
