gean_3054931
can anybody reply to below thread?
FX3 JTAG SEGGER
thank you
KandlaguntaR_36
It is answered in thread FX3 JTAG SEGGER
Please set the following breakpoints in the firmware and do stepover at KernelEntry
By default the debugger stops at Main.
1. Put a break point at application define function (CyFxApplicationDefine)
2. Otherone at Thread_Entry function (for example - UVCAppThread_Entry in UVC An75779 firmware )
After this, if you do stepover at kernelentry, it will take you to Application Define. Then it will take you to Thread_Entry.
Hope this solves your problem.
I have tested at my end. It is working fine.
KandlaguntaR_36
