Hello, I met a following error recently on FX3:
- First I sent a control write transfer to the fx3 from the host
- The fx3 needs some time to process it, but the host receives a response with URB status: No such file or directory (-ENOENT) (-2)
- The host send the same control write transfer to the fx3 again
- This time the response becomes a USB status: URB status: Protocol error (-EPROTO) (-71)
Please see the attach capture, thanks in advance
I noticed that you are using a different PID for your FX3 device.
Please confirm that you have included the VID PID in cyusb.conf (configuration file) of FX3 SDK for Linux
Rashi
Please let me know which API is being used for sending the control request to FX3. If possible, please share the code snippet of the host application when the request is sent.
Are any transfers done to /from FX3 before sending the control request?
Rashi
Hello, I send the control transfer through cyusb_linux, the configuration is shown below. It is the first command send to the fx3.
Please let me know why is the device type coming up as "FX2" instead of "FX3". Could you please select the device from the list of devices and then do the transfers
Rashi
Hello, even if I select the device, it still give the same results.
Please let me know which firmware is being used for this test. Is the vendor command handled in the firmware?
Rashi
Hello, this is developed by ourselves, and the vendor command is handled in the firmware. But before call CyU3PUsbGetEP0Data , there is some time delay in the firmware. Even though if the delay cause a timeout, it still shouldn't give No such file or directory (-ENOENT) (-2) error, right?
Yes, your understanding is correct.
Does removing the delay before CyU3PUsbGetEP0Data improve the issue?
Also, let me know if any USB transfers are done before sending this vendor command. If yes, where the transfers successful?
Rashi
Please let me know which driver version and OS/kernel version are you using. Also, can you try using command line applications in the fX3 SDK for Linux and check if that is working fine?
Rashi
Hello, do you know how to check the driver version and OS/kernel version? I used the cyusb_linux to send control transfer.
Please let me know the driver/libusb version using this command.
dpkg -l libusb-1.0*
Also, let me know the OS/kernel version
uname -r/uname -a
Rashi
Hello, thanks for your reply, here are the results:
~$ dpkg -l libusb-1.0*
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii libusb-1.0-0:amd64 2:1.0.23-2build1 amd64 userspace USB programming library
ii libusb-1.0-0-dev:amd64 2:1.0.23-2build1 amd64 userspace USB programming library development files
ii libusb-1.0-doc 2:1.0.23-2build1 all documentation for userspace USB programming
~$ uname -r
5.15.0-46-generic
~$ uname -a
Linux yudi-office-ubuntu 5.15.0-46-generic #49~20.04.1-Ubuntu SMP Thu Aug 4 19:15:44 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Apologies for the delay in response.
Please let me know if the default vendor requests in the USBBulkSrcSink pass on your setup. Please follow this test sequence
- Program FX3 with Default BulkSrcSink firmware
- After the device enumerates (check using command lsusb -v ), try sending the the vendor request supported by UsbBulkSrcSink for example
Direction: IN Request: Vendor Target: Device
bReq = 0x82 wLength / bytes to transfer = 32
wValue = 0 wIndex =0
Rashi
Rashi
Hello, this success
Please try to use VID: PID - 0x04b4: 0x00f1 (same as Usbbulksrcsink) in your firmware and let me know if it works
Rashi
Hello, do you have any update about it? I'm wondering if you could reproduce it on your side with the code 🙂
