shovalk
5 replies posted 5 sign-ins First reply posted
hello all.
I'm a newbie so my question might sound trivial.
I'm trying to get my ARM-USB-TINY-H to debug through jtag a cypress FX3 on a custom board.
I've succeeded to flash out an example to the FX3 using the USB3 connection, but it doesn't have debug capabilities.
can anyone point me to the right direction on how to get it to work?
Rashi_Vatsa
Please confirm if you have replaced the OpenOCD binary with the a version that is supported by ARM-USB-TINY-H.
As per the EzUSBSuite_UG
A version of OpenOCD binary that supports debugging using the CY7C65215 part is provided with the FX3 SDK, under the OpenOCD folder. This binary is based on the OpenOCD 0.8.0 release and only supports the CY7C65215 part as a debug interface.
If any other OpenOCD compliant debug probe (such as the Olimex ARM JTAG debug probe) is being used, replace the OpenOCD binary provided with a version that supports the target debug probe. The rest of the instructions are interface independent, and apply to any OpenOCD compliant debug probe.
Please refer to the links provided in EzUSBSuite_UG.pdf
Rashi
Rashi_Vatsa
Any of the standard JTAG debug probes (such as  J-Link /OpenOCD) can be used to do run-time debugging of the FX3 firmware.
As per my understanding, Olimex Arm-USB-TINY-H probe supports OpenOCD. Is my understanding correct?  If yes, you can refer to section 3.2 of EzUSBSuite_UG of the SDK for debugging steps using Open OCD.
Rashi
shovalk
so i tried the exact configurations as EzUSBSuite_UG 3.2, i dont have any errors as i press "Debug" (normally it gives a - "Error in services launch sequence" error), i starts the green loading bar, but when it hits 62% it just stops there and not loading anymore (no error is shown).
can you please advise?
Rashi_Vatsa
Please let me know if you are using the EzUSBSuite from the latest SDK 1.3.4
Also, share the configuration snippets for us to check
Rashi
sorry for the ignorance, but i couldnt figure out how to find the SDK version - though im sure im using 1.3.X.
attached the debuging configuration.
the configuration file is :
# OpenOCD configuration file for Cypress FX3 (ARM926EJ-S).
# FX3 has a standard ARM JTAG TAP and can work with a standard ARM926EJ-S configuration.
# The interface selected below is the CY7C65215 based JTAG debug probe. If another
# debug probe is being used, just replace the "interface cy7c65215" line with the
# appropriate interface name.
gdb_port 3333
interface ftdi
# Target: CYPRESS FX3 ARM926EJ-S
if { [info exists CHIPNAME] } {
set _CHIPNAME $CHIPNAME
} else {
set _CHIPNAME fx3
if { [info exists ENDIAN] } {
set _ENDIAN $ENDIAN
} else {
set _ENDIAN little
if { [info exists CPUTAPID] } {
set _CPUTAPID $CPUTAPID
} else {
set _CPUTAPID 0x07926069
#delays on reset lines
adapter_nsrst_delay 200
jtag_ntrst_delay 200
adapter_khz 1000
reset_config trst_and_srst srst_pulls_trst
jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag_rclk 3
# Target configuration
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME arm926ejs -endian $_ENDIAN -chain-position $_TARGETNAME -variant arm926ejs
adapter_khz 1000
################################################3
thank you very much for your help.
Rashi_Vatsa
The SDK version can be checked from the build variable of the project settings (refer the attachment)
From the snippets, I observed that in the Debugger Tab > "GDB Client Setup" > Executable, is changed. Please refer to EzUSBSuite_UG and change it default setting - ${cross_prefix}gdb{cross_suffix}. If you get an error of gdb --version, please change the {cross_prefix} variable must be set to arm-none-eabi-
Rashi
hello and thank you for your reply.
i am using SDK 1.3.4.
i tried as instructed, i have error : arm-none-eabi- gdb{cross_suffix} --version.
also i have --version error with the default ${cross_prefix}gdb{cross_suffix}.
please advise.
Rashi_Vatsa
Please replace the following in the executable field and let me know the results
$arm-none-eabi- gdb{cross_suffix}
Rashi
Hello Rashi,
i still get the --version error.
attached.
please advise.
Rashi_Vatsa
Can you please delete the current debug configuration and create a new configuration by following the steps and use the settings as mentioned in the EzUSBSuite_UG.
Please share the results and the Debug configuration snippets if error is seen again.
Please do not change the default settings of Debugger Tab > "GDB Client Setup" > Executable.
Rashi
shovalk
i tried as you instructed.
deleted the debug configuration and created a new one according to EzUSBSuite_UG.
it is not working , attached are snippets of everything I've done.
please advise.
Rashi_Vatsa
Rashi
